Document data - how to add info in a document
If I put the data in a document, can it be updated in the other pages of the document?
For example, I want to complete a draft, in which only certain information is changed. I would like to create a document where I can put the data that changes and update the document with the previously filled information.
Hi @Maximize_Ecommerce and welcome to the Coda Community!
I read your description multiple times, but couldn’t understand what you are trying to achieve.
Can you add additional information or optimally share your doc, so we can take a look at it? It is much easier for us to help you then.
You can find a guide here:
Sincerely
Jannis
