A section which allows you to easily plan your timetable for the day or for the week! Maybe something like a daily notes section like what is used on capacities platform.
I have tried using the calendar function for this, but it takes quite a lot of effort to add new things to do for each day as you have to add a new event/item for each part of the day.
If there was a specific function to fix it that would be relaly cool to seee.
- List item
