Embedded Link to display info to general public
Hey Coda friends
When using the embedded share functionality,
1- Is there a way to display only the filter and sort options without any of the other components ? see the pic below.
2- Is there a way to see the filter and sort functionalities when viewing the same cards on a mobile device ?
Thank you for your insight.
Thank you
Hi @Bruno_Levine,
Welcome to the Coda Community!
A good way make filters more accessible is to use our “Interactive Filters”. These add a canvas control that can be used to change the filter in the table.
Here’s a help article on adding these types of controls:
And here’s a screenshot:
Sorting can also be done, but it requires a little more work with the controls and the table formula used.
Hi and welcome!
And here’s how to do sorting / grouping with in-page controls, if you’re interested:
