Employee Onboarding with Knowledge Test
Currently I am working on an employee onboarding that includes presentations with a quiz after each one. Does anyone know of a way to add logic to a select list that would show an error if the answer in the quiz was wrong or anything similar? These are not difficult quizzes but we need to be able to capture when someone completes them and if there is an area that people struggle with on the information.
Thanks for any help you can provide.
Hello,
If I’m not mistaken :), the use of a formula with a list containing the expected values in response should do the job ^^.
Sincerely,
Thierry
Hey @Terry_Stagg,
There are different ways to achieve it.
Have a look a this simplified example and tell me if this is going to the right direction
I hope this helps.
Cheers!
Yes this would work. Thank you for your help!
