clicking on an embedded mermaid diagram enlarges it and tries to render it in DARK MODE. There is no control over which colors are chosen and therefore the diagram becomes invisible / unusable.
If you directly switch the document to dark mode with an embedded mermaid diagram the same thing happens.
Has anyone seen this ?
Normal Mode:
is properly visible.
Dark mode: Note the arrows and any text on them is not easily visible.
mermaid is an amazing tool, but this is a show stopper for us.
This sounds like this issue may be related to this specific Pack. Therefore, the pack maker is going to be the best source of support with this issue, as we cannot make changes to a third-party pack directly. You can do this by reaching out to them at their support contact listed in the About tab for this Pack.
If it is a bug, we recommend sharing what browser you are using, screenshots, or a screen capture of the undesired behavior, and sharing the steps taken that present the issue.
Please keep in mind that Pack makers are not required to implement any feature requests.
Anything else I can help you with in the meantime?
