I’m getting the following error when trying to copy pages from one doc to another. One doc is Coda version 175 and the other is 176 (according to the stats on each doc). I just want to move a few pages over and keep the formatting instead of copying over just the text and having to format everything all over again. This is the first time I’ve encountered this issue. How do I get doc v175 to get with the times and come to v176? TY
Upgrading Coda takes some time to cover all docs. I tried again the next day, and the docs were on the same version.
If the issue is urgent, use the ? bottom right of your doc and ask support if it is possible to immediately upgrade the old version. Hopefully they are able to process an exception
P
