is it possible to add the Currency select list after you set your column as currency. Today I change from text to Currency and I get the default Dollar. I have to open the column, select the second option and open the window to check the Euro. Since I do this more than once in a while, it would be great to have this logic in one flow. thx for your consideration.
ps a default currency suggestion based on the selected time zone would also be good for me
cheers, Christiaan
