Expanding/ Collapsing option not appearing
in left option (three dot button), there is no Expand/ Collapse option. different from other table.
is collapse table disable, can it be show again , because i want the table be collapse ?
Is your table aligned to the far left of the page?
You can not collapse it if you have indented it.
thank you for answering.
Yes, seems it far left of the page. how can it be indented? what should i do to make it back again ?
