When writing complicated formulas it can be pretty tricky to indent properly to understand which brackets match which brackets. Would be nice for the formula editor to automatically format your code such as what Prettier.io does.
Hi @balupton - I feel you, formulas can get quite complicated sometimes. When you expand the formula editor we show an “Auto-format” button that automatically formats for the formula for readability.
Cool, never knew that!
Is it possible to have this run as you type? Or have a hotkey for auto-formatting?
If you hover over the button it will show the shortcut to use.
