Filter formula to filter if control checkboxes are checked
I have some control checkboxes (lets call them checkbox 1, checkbox 2, etc) and I want them to apply filters to a specific column (Columnb B) in a table when those boxes are checked. If no boxes are checked, I want all of the filters to be removed for that column. I can’t seem to find any definitive answer to this in the available documentation. Thanks!
Doc link below. I am starting with just 2 checkbox controls for now. I’ll add the rest of the controls once they start working…
Alternatively, I would be open to accomplishing the same goal with control buttons but I couldn’t get that to work either, even when linked with a dropdown control filter.
Hi Brittany,
Welcome to the community!
It would be much easier to help you if you would share a doc with what you tried so far.
Pablo
Done! Thanks for the tip
If both checkboxes are true… you want both filters to be applied with OR or AND?
So column “Services & Topics” needs to contain
  • both Education AND Career Interest Exploration
  • or one of the two checked values?
either/or. One of either of the checked values.
Is there any reason you specificaly want checkboxes?
Because you can just create a control value with a multiple selectable pick list.
So you can select e.g. education, career interest exploration or both…
If I understand correctly what you are trying to do, the filter formula should look like this:
