I’m trying to use the BusyTimes formula from the Google Calendar pack to filter out all rows in a table that have an overlap with my “Ryan Martens Default” GCal. When I use the formula directly on the canvas, it works as expected, returning a list of event start times within the specified range. Strangely, it also works perfectly in the formula preview (see screenshot below), but the column value stubbornly remains []
for every single row, whether or not there are overlapping times.
I’ve tried refreshing the connection and extending the date range of the formula. It consistently works fine on the canvas (even pulling in the exact same row data via formula) but does not work in the column.
Any suggestions for workaround while this gets fixed?
