Hi. I need a formula to add 0 to the left side of a number, so that it always ends up with 3 digits.
For instance 1 => 001 15 => 015 134 =>134.
Is there a simple way of doing it. (Maybe using RegexReplace() ).
I didn’t want to use if()/concatenate() for this case.
Use the LeftPad formula.
LeftPad([Column],3,“0”) should get you there
