Hello,
We are still waiting for this feature and Notion has already implemented it, not only that, but they have translated the entire interface.
It’s really frustrating that the app I want to stop using (Notion) has implemented the feature we’ve been asking for for so long in the app I want to use (Coda).
Sadly I’m still unable to use Coda because of this and I’m still using Excel and Notion and keeping an eye on Loop
Really huge +1 to implement this!
We’ve been shying away from building client-facing dashboards in Coda so far because of this …
+1 for this- I believe especially for accounting purposes this is critical for clarity.
Regards
Luca
this is kind a bummer for an aged request since 2018. Hopefully this will be heard soonest as patch small quality-of-life improvement rather than the recent big-thing feature releases. Hopefully for more inclusion of more currencies (Peso philippine, etc) or custom prefix/suffix field.
When this feature will be available? We can simply configure this into the Settings panel.
+1 for this feature
(I wish I could replace the “,” separator for thousands by a space like we do in France)
Support for using number and date formats in different countries.
It is sad to see that Coda has ignored this subject for 6 years now and has not even commented on it (except for a laconic “No updates” two years ago).
For presenting purposes I usually setup a column with a regexReplace formula to format the currency data properly to brazilian portuguese.
It’s basically a nested regexReplace: it first replaces the comma with a pipe, then the dot with a comma (in PT-BR we use commas to separate the decimals), and lastly replaces back the pipe with a dot (our thousand separator).
RegexReplace(RegexReplace(RegexReplace([yourvalue],“\,”,“|”),“\.”,“,”),“\|”,“.”)
Since you replace the original comma to a space, you could use the formula:
RegexReplace(RegexReplace([yourvalue],“\,”," “),”\.“,”,")
Can Coda please let us know what’s the status in this? It’s super annoying and to be honoust unacceptable for some of my customers.
Yes, it´s simple unacceptable, every app system out there , airtable, seatable,… among others have this option of localization and in the case of Coda is a matter or years.
When I need to send reports to the Spanish Public Official Administrations the refused them, change the figure format!, by hand?, please Coda, this is serious.
Absolute must-have to be able to copy paste fast from other apps like Excel, calculator, etc. using local separators.
Hello @Al_Chen_Coda !
Would it be possible for you to share Coda criterias to consider a feature ? (Any minimum number of votes ?)
(Not considering this one is so strange to me, I can’t get why you work on other new features without tackling basics (for the rest of the world at least
) like this one).
I know some workarounds are possible (I added some formulas in my personal custom pack for this), but this is so geeky and boring to be forced to do that in 2024… Trying to convince other french people to go for Coda instead of Notion would be so much easier with that kind of basics available…
Also : Is there any kind of public roadmap we can look at to know what is in the pipe for the next months/year ? That would be really appreciated
Kind regards
Hello,
I would like to UP this because not being able to read and manage numbers according to our needs can be a deal breaker to some of us. I am fighting to get CODA accepted within my company but I am afraid that such a stupid thing might put it all off.
Any roadmap or official answer about delivering this anytime soon ? The solution from @hugo_assuncao is very nice but doesn’t really solve the issue for those working with number within coda itself.
Many thanks for your reply.
Best regards,
Yannick Pinta
Just another formula to make this, but simpler:
thisRow.Money.Split(".")
.ForEach(Split(CurrentValue, ",")
.forEach(
CurrentValue.Join(".")
).Join(",")
This is not the best solution, for sure, but it is a option. The translation (localization) and currency format are both things that I do not understand why is so hard to implement - we are talking about years, but anyway…
everyone, new currency format options, default currency options & format formulas are now live—read more here!
