Is there any way to group a table in detail view, so that you can navigate it primarily by reference to the name of a parent row? If there is, I can’t find it XD
All I figured out how to do was create a view with a different display column, but that just displays that column repeated; it doesn’t look nice at all.
As far as I know you cant use grouping with a Detail view for a table.
