Hello to everybody!
Suppose my question is quite easy to solve, but can’t figure that out.
Here is my table:
I want to create a view “Detail” of offers like:
Offer1
Jan IT 100$ 1
Feb ES 200$ 2
Also a view of Advertiser:
WF
Offer 1 IT Jan 100$ 1
Offer 2 IT Jan 400$ 4
So will be able to check in “detail” view what countries has that offer, see the profit and sales for each month etc.
Same for advertisers - i will be able to check what offers advertiser has, what countries has those offers and stat for each country.
Thanks in advance!
Hi @Rat_Race,
and welcome to Coda Community!
Have you tried Group By option?
Top-right of your table > Options (opens right Table options panel) > Group, then select the group by files (offer name or Advertiser).
Is this what you intended?
In case, if you could share your doc (top-right of page) it would be easier to better understand and/or work directly.
Cheers!
I would recommend that you create an “Advertisers” table and change the advertiser column in the offers table to be a lookup from that table, then, in the advertisers table, you can get all the offers that relates to each of the advertisers and create a detaile view of that table.
Thanks, Federico!
Asaf_Dafna - suppose that is the solution!
And i think i can also do the same with Offers to create a “detail” view!
I tried something similar but couldn’t solve “month” problem.
Will come back in a few days to solve month problem
Thank you guys!
