How do you get rid of the ? help button on the bottom right of the screen that covers the scroll bar??
Dear @Lynda_Reilly,
It is not possible to be removed, as it’s part of the interface.
What’s the reason you want it to take away?
I am sure the Codans will appriciate when you could give more details and maybe a sceenshot and your config like screen resolution etc.
You can send that directly to support@coda.io, and I am sure they will have a look.
Hello,
It sits on the scroll bar which when working towards the bottom of my sheets it is in the way. It would be great if it could at least be moved to another area of the pages.
