Help | Clickable links in csv when downloading table in coda
Hi, I have clickable links in a text column on a table.
The text itself describes the document as putting it as the link itself is too long.
However, when I download the table as a csv, the link address is lost and you only get the text now.
Is there a way to fix this?
Dear @anon36717443,
What is obviously for you, is for sure not obviously for everyone.
I recommend to share a doc where you show what you have and try to explain what you want to achieve.
Chances that a solution can be offered rise significantly.
Hey @anon36717443 ! Thanks for reaching out. From what we can tell, it sounds like this might be a limitation. That said, we have tracked your vote for the following feature request, when downloading a Coda table as CSV preserve hyperlinks on the output file, and moved this post into the Suggestion Box for other members of the Community to chime in on this. We’ve gone ahead and tracked your vote for this feature formally.
