Hiya! I’ve been using Coda to sort my d&d characters for d&d 3.5 for some time now- but I’m absolutely hopeless with tables. They’re the bane of my existance, and partly why I came to Coda instead of Exel, becuase it’s a bit more user friendly. I understand the concepts, but don’t know the terminoligy to get what I want.
What I’m essentially trying to do here is have this:
A table “tracker” where I can input the value of EXP we get each session. I can add things like date for record keeping, but this shouldn’t effect anything else.
From there, I have it summerized as “Current EXP,” which shows the Sum. This is where I get lost.
What I want is for the Sum total of Current EXP to be compared against the “EXP” chart (the one on the left) to tell me exactly what level that equals. This seems like a really easy thing to do in theory, but I don’t know the theory. (sob)
So, in this example, with the three entries in the tracker I have, the Sum being “10,392,” If I have a “Current Level:” Formula, it should say “5”, as per the EXP chart on the left.
That’s the main thing I’m after
Beyond that, I also want to know if I can make a “Progress tracker” between the level I’m on and the next level (So the amount of EXP required between two levels). Again, it feels like it might be a very simple formula I’m after, I just don’t know it. (Please ignore the 753 in there. It doesn’t mean anything. In theory, right now this should be a scale between 10,000 and 15,000, where the total is 10,392 at the moment.)
Any help you can offer would be amazing, whether it be more thorough or just a video you can direct me to to learn this specific solution. Thanks in advance!!
