Hi i’m struggling in finding a way to connect my projects and add tasks and subtasks to them.
It’s essentially a Jira emulator. So basically a way to go in a project and add tasks linked to them and subtasks. Certain projects would have linked-projects too. And the epics would be able to be linked to sprints.
I feel like this MUST have been done before. Could someone please direct me to the relevant resources please?
Your project is super doable - Basically it will come down to holding a table with your tasks and then have another table that references the task table via a lookup column to hold sub tasks.
You can then reference the sub tasks in the main task table via a filter like: subTasks.filter(lookupColumn=thisRow)
Here is an example Project Management document I created that actually has 4 layers of sub-tasks! It’s pretty wild but works really well.
Feel free to make a copy and take a look at my formulas and all the logic behind it making it work.
