I’m new in Coda, and I’d like to use Coda to give more power to my Notion but I’m having a few problems.
I’m using a pack and in it there is a limit of 10000 rows and one of my database in Notion it’s synced with Google Calendar, so when i sync i received all my old entries but not my new one, what is a possible turnaround to have my new entries sycned?
if you use Notion you know that self-filtering sometimes is really useful due to some limitation of the app, so I’d like to automate this with Coda, in this way, sync Notion pack in Coda, then in a empty column I’d like to do a formula to mimic the “Name” and send it back to Notion so that i have there the relation.
I’m not really practical, is there anyone who has experience with Notion pack that can help with this?
Right now the Pack does not support filtering, a quick fix could be giving you the option to select ascending or descending order for the sync. I will let you know once implemented.
I don’t quite understand this point, if you want to update a Notion page you have the UpdatePage action, which property type you want to update from Coda?
