When you try to delete columns, sometimes it says that they will affect formulas inside of items named things like “##hidden_control## 22”. How does one go about finding an object like “##hidden_control## 22”?
Hi Matthew!
- Click to the right of the table name
- A menu is opened to the right, expand them, I think hidden controls are usually unnamed canvas formulas?
- Click a formula to highlight it in the doc
- Profit!
@Rickard_Abraham Do you know of any indications on which Unnamed is a specific number? E.g. Unnamed 1 is ##hidden_control## 1 and Unnamed 232 is ##hidden_control## 232 (like in my case)?
I don’t think so I’m afraid ![]()
