In kanban view, the done column gets long after some time. Is there a way to factor the age when they were moved to the done state and then filter them out (e.g. after 2 weeks)?
Yeah!
Run a Modified() formula on the status column which organizes your Kanban
Then run a filter on your table that says:
Hey Coda, show me only rows in my table where the status column is not equal to Done or the status column IS equal to done and it’s been modified in the past week
Aka:
Status!= Done OR (status = Done AND ModifiedColumn > today() - 7)
Thank you. Worked perfectly!
