How do I hide done tasks
I knnow there’s already an answer to that but I have no idea what the answer is talking about and to follow it. I have a to do list and I just want the row to disappear (or do some other action) once the Done columns is checked. Please help
Try just filtering a view on the the items whose Done column is not checked…
Hey @Karolina_Markytanova,
as @Doug_Loud already said, i suggest you to create a DB Table where you store all of your data and create a view of that Table where you filter the data…
I just created a example doc for better understanding.
Please take a look at it: https://coda.io/d/_dIG5nG7H9fU/https-community-coda-io-t-how-do-i-hide-done-tasks-41018_sujGq
Hope that helps.
Sincerely
Jannis
