Filtering out Done tasks
Hi, how can i filter out done tasks (check box) without having to create a view of the table?
Hi Nicolas,
Welcome to the Community!
You can use the filter at the top of the table. You could also go to the column, and in the column menu go to the filter entry there.
Regards
Piet
