I was using the detail display, and wanted to make different pages, but it would only assign one layout to the table. Is there a way to assign a layout to a row?
@Clayton_Cornell yes make a view of the table, and then you can change the display type of the view.
What did you have in mind? Perhaps if you were more verbose I could help more. You can create another page and move the view there since you said you want to make different pages.
Hey Clayton, thanks for asking your question here. If I’m understanding correctly, it sounds like you want to set different layouts for various rows within a single table/view. Unfortunately, this isn’t possible currently. You can only specify a layout on the table/view level, as Johg_Ananda suggested. Sorry for any inconvenience!
Technically, there is also an unofficial way to get custom views depending on the row. It takes some manual setup, however.
