I have a table that lists out clients and all the different roles that are relevant to that client (ie. facebook manager, google manager, UI/UX manager, email manager). The final column on this table is dedicated to the ‘team’ - where all of the people contributing to these roles from that client-specific row are listed out in one cell - is this possible?
I think its possible - it might depend on how you are treating the ‘people’ column; what type of column data do you have it set as? (text, lookup, people, number, etc)
Hey @Tim_Gachot think you’d have to share how your roles are set up as well. Is there 1 person serving each of your defined roles? (FB Manager, Google Manager, etc…) or are there multiple individuals serving those roles. If it’s the latter I think at some point you’d still have to select the specific individuals serving in those roles, which you could accomplish with a lookup column type and switch on the “allow multiple selections” setting.
Hi @Tim_Gachot, from your description I think I’ve been trying to solve a similar problem. I have separate people columns for each of the team functions (i.e. design, front-end etc.) and have been trying to create a “Full Team” column which shows all of the people involved in that row.
I played around with SWITCHIF for for a while and am now using a LIST formula with IF statements within it. This works but I haven’t figured out how to handle blank values i.e. columns with no team member in so the results look a bit buggy at the moment.
Have you tried something like :
Filter(IsNotBlank(CurrentValue)) or something like it ?
It might not work, as it depend of your formula, the type of your field and generally speaking, how you build your doc… It’s just an idea
Great question here and it’s not necessarily an intuitive formula that can make this work, but @Pch has the right idea. Using ListCombine() and Filter() will make this list possible.
ListCombine([Column 1], [Column 2], [Column 3]).Filter(CurrentValue.IsNotBlank())
I think that should work.
List() can create (One, Two, [Three, Four, Five]) where [Three, Four, Five] is considered 1 item.
ListCombine() flattens it and makes this (One, Two, Three, Four, Five) and is considered 5 items.
