Hi everyone
Iβm creating a chart in Coda that shows the total hours, but when the values go over 24 hours, Coda automatically converts them into days.
For example, if I have 22h + 22h, instead of showing β44hβ, the chart displays β1 day 20hβ.
Does anyone know how to make charts display the accumulated hours as plain hours (like 44h) without converting them to days?
Thanks in advance!
my suggestion would be to add a column to your table called Hours with the formula
ProjectDuration.ToHours().toNumber()
so it computes the hours as a plain number.
then you can use that in your chart.
max
actuallyβ¦
i believe .ToHours() returns a NUMBER and not a DURATION
so you probably do not need to add the .ToNumber() at the end.
max
but I want the chart to show something like this: 44h 30min, not like 44.50. thatβs what Iβm not sure can be done in Coda
use the Format() formula to define how the hours and minutes should be displayed
Format(β{1:00}:{2:00}β,DURATION.Hour(),DURATION.Minute())
This pads the hour and minute values to 2 digits each with a colon between them
@Carlos_Moreno
you can set the duration column to show only hours and then create a helper text column pointing at duration column and it will display as your intended format i.e. 44hr etc
here is the reference you can copy should you require more detail.
hope this helps!
Cheers!
Mel
