When I use a lookup from a table that has grouped items, I often only want to select one of the many duplicate names in that table. How do I filter the Lookup options so that only one unique option shows up.
I have already tried Item settings -> Filters like: [Target Table].Unique() Name.Unique() [Target Table].Filter([Target Table].Name.Unique().FormulaMap(RowId(CurrentValue)).Contains(CurrentValue.Name.RowId()))
The essential usecase is a way to build out packages containing multiple components. I want to be able to select the packages and then order all the internal components (without having to select the components individually). Does that make sense?
