Hello everyone!
I’m trying to create a time-based automation on a table that performs an action for rows that have a checkbox that is unchecked.
I’m having trouble referencing the field correctly.
I’ve tried things like:
thisrow.[complete] == false()
false(thisrow.[complete])
But in each case it appears that thisrow.[complete] is not the correct way to reference a field.
How can I do this?
Hey @Chris_Hall ,
I’m doing something similar and I remember that I also struggled with that. I worked around it in a different way, maybe it helps:
- I’ve added a button column in the table. The button runs the action I want to automate. E.g. change column value or post to slack
- In the THEN I filter the table and run the button for all rows with empty result column (in your case false checkbox) with
[tableName].filter(result.isblank()).[ButtonColumn].RunActions()
That way you don’t need to reference any “thisrow” or “result of step x”.
Is that what you mean / would that work for you?
