Hey! I’m looking to trigger automations based on when a time is reached within my table.
What’s the best way to do this?
Hi @Joe_Kattan
Fornow you can trigger automation on absolute time, and when a row is changed (we wont speak about webhook here)
So there is my proposal :
TimeToTrigger=Now()
. The checkbox will briefly goes from false to true and false again when Now() will hit the value in your tableThanks for the idea by the way, interesting use case !
Let me know if its ok for you
Cheers
Q.
You actually can’t trigger an automation with an formulaic column. I’m not sure how you’re automation went through, but I can see that the “Now” checkbox is not checked…
Yep that’s what I just figured… after my automation run anyway ahah cant explain that one… !
If you need it to run at an exact time down to the minute, you can use @Leandro_Zubrezki scheduler pack.
Leandro can you link it??
Yes 100%, you have a couple of options:
Oh my ! So cool, the worst with packs, is that sometimes we do not even know they’re are, just waiting for us Thanks mate !
