I’m trying to setup my grading system to be in coda instead of excel and I’m having some trouble. I can’t figure out the best way to display all this layered data, other than having each doc be a term and each page be a subject (where the table is filtered by that subject). Below is my old system in excell, and I’ve noted the names for each data set in coda.
Ultimately I want to calculate the averages for each component, and subcategory, and those averages should add up, based on how much they count towards the final grade (aka their weight), to give the final mark.
Have a table of students, where you have a relations column to the assessment types:
For each assessment, Coda shows the component/ Sub category etc in this table.
You can use the below to capture assessment scores:
As soon as you enter a new row by clicking on the “+”, it will populate the assessment in the filter. You can then select the student name from the drop down list.
You can also group along the top, but I do not particularly like that layout.
You included a notes and a check box column. I was not certain at which level those were - for assessments or for students. If you want to store additional info for each individual student, you can also change the student column into a relations column. (Start by making the column a select list, then go “edit → column” - create table.
