Idiomatic way to add a row in another doc in Nov 2023?
Requirements
  1. The triggering document needs to send data to the target document, e.g. to create a new row in that document with incoming data.
  2. The action in the other doc should be relatively immediate, so using a cross-doc table to trigger something in the other doc is too slow.
  3. Ideally very straightforward, using standard formulas and actions.
In the past what I’ve done is:
  1. Create a form in the target document to trigger the action in.
  2. Create a button in the triggering document and then open a window to the target document’s form, feeding input data into the form’s URL parameters.
Example formula:
OpenWindow(
  format(
    "https://coda.io/form/formName?param1={1}",
    thisRow.RowId,
Are there better alternatives today? Perhaps by using the new document embeds?
Thank you! :slight_smile:
