I really wish it’d be easier to navigate tables. As I keep using coda more and more complex tables get formed. If when scrolling down you could anchor the top ‘description’ row on the top of the page, that would help navigate tables better and to know where you are.
And if one groups something, then keeping the group blocks anchored on the left while you can scroll the table will help that one doesn’t loose reference of what you’re looking at.
I think the top and left anchoring are crucial for better navegability and usability.
