Hi,
I want to send off some data to an SQL database from a table in a Coda document. Is there any plugin for something like www.stitchdata.com or similar?
Thanks,
Dylan Erens
Hi,
Thanks,
Dylan Erens
you could use Zapier to connect Coda with StitchData. these links should help you
Thank you.
