I have an interactive control that is single select. (I not allow multiple selections.) The filter in the column uses Matches(). Is there a way that I can make the control not default to selecting ALL options? I wish to select one option at a time.
Hi @lynnvk,
Welcome to the Coda Community!
If you’ve set the interactive control, then chose an option, it should default to that each time you visit after. It should remove the multiple select option from the actual dropdown. Let me know if I misunderstood the question.
