Hello Codans,
I work in a bilingual environment (English and French) and with partner organizations who speak on or the other language.
Up until now, when creating tools, I have been naming column headings in both languages (eg: Nom :: Name). This works fine when the names are fairly short but when trying to use explicit headings (eg: Communauté de mise en oeuvre :: Implementation community), the heading becomes quite long.
Without having to create two separate tables (one French, one English) and then combining under a single one, is it possible in CODA to change dynamically the headings?
Say for example a user selects French (through button or toggle), the headings across tables will show in that specific language. Obviously, I will need to create a table with language equivalences.
Is there a way of interacting with the headings in tables or the structure of a table?
Many thanks in advance for your insights.
