I am using tables to print a page on my Coda doc in one of my projects. The referencing (with @) and in-doc formula capabilities work really well for this and gives a dynamic view which can then be embedded.
The only issue is that I am unable to format the text to any great degree, the references have over-running colour format and the formulae have the grey round box showing up kind of uncomfortably.
Is there any way around this? If not is it something Coda has in the works?
