Good day, dear coda community.
I am wondering is there any way to make a text or formula output from tables in numbers really big and eye-catching?
Now the biggest I can do is
There are lots of ways! The easiest is simply to highlight your text (those numbers that are the output of a formula) and format them as H1, H2, or H3
Tried finding a Pack that’d return an image of the requested number but don’t think there is one.
A bit of a weird idea but it kinda worked, use wordclouds with a filter like this!
There’s an annoying bar in each wordcloud but I think it could work for some cases!
Good day!
Thank you for your reply. Yeah, I know about H1, H2 and H3, but unfortunatelly, they are very small.
I would like the number to be really big!
Hello, Rickard.
Yeah, that’s close to want I would like to have as a result.
Thank you for your suggestion, will try.
Looks like I managed to do it as you suggeted, but not all numbers are shown on (in the last table it is not working, should be number 9)
Also, do you have any idea about colors? Is it possible to change it from blue to different one?
