One snag I just encountered is when my doc contains both tables and sub-pages. As such, I am only being prompted with the “Include subpages” copy option, no options related to rows to include.
“Copy to doc” issue
If a page you copy to another document contains tables, you are being asked
- if you want to include subpages, and
- whether you want to copy the table rows or only the column headers.
If subpages of the copied page contain tables, you will be asked only if you want to include the subpages. The table rows of tables in the subpages are never copied to the target document.
Maybe this is by design, nevertheless it’s an issue. There should be an option to copy also the values of rows of tables from subpages.
And is it just a copy? The amazing feature will be if we can connect the copy to the original so that it updates automatically
Yes, it’s an independend copy.
At least you can synchronize tables across docs, using the cross-doc pack (synchronization is in one direction, values can only be edited in the source doc’s table).
Hi, I’m glad to share with you that this issue has been fixed.
Thanks for the report.
Jesus.
Thank you, now it works as expected!
Now the values of all tables (on pages and subpages) are copied when selecting this setting in the dialog box, no matter on which pages there are tables. The dialog box lists the copied tables before confirming (“Rows to include”).
Wonderful, I have some copies that I can now do!
