Launched: Undo Section Addition & Deletion
Sometimes we all wish we had a little bit of a bigger safety net, which is why today we’re making it possible to undo deletion or addition of a section in Coda (and to redo deletion if you really want to get rid of it!).
Now, when you delete a section or add a section, you can use the undo and redo delete buttons in the top menu to reverse the action.
Standard keyboard shortcuts for undo/redo will also work for this action, too.
  • On a PC: Ctrl + Z for Undo; Ctrl + Shift + Z for Redo
  • On a Mac: Command + Z for Undo; Command + Shift + Z for Redo
We hope this helps you make, organize and manage your docs with even more confidence!
ー Adam
This is awesome. Thanks!
Here’s something which currently appears to not be revertable via undo:
Consider allowing undo to work in that case as well. :slight_smile:
Hey Eduardo, thanks for surfacing this. Will respond on the thread.
@adamginzberg64 how do I get the top ribbon with the back button to show? I cant find a way to add this to the tops of my pages.
Undo and Redo buttons are now in the doc menu on top of doc :wink:
