I use select lists quite a lot, sometimes I want to just toggle between 2 or 3 options and think it would be great if this could occur with a cross between reactions and select lists. Where you can choose a group of icons (like you can with reactions) and and then when you click on the icon instead of opening the drop down, it instead cycles through the icons you’ve selected.
Here’s a mock-up using reactions that shows what this suggestion might look like in practice.
