I’ve always hated that cards are cutting off the text when longer. After using it for about an year I decided that this hack might live longer for good and it’s worth sharing it.
What you need to achieve it:
a) A special Unicode character or emoji, or
b) Use one of the text formatting formulas like _color( ) and _bold( )
EDIT:
Here is a link to the sample doc page along with the video demo on this same page:
Super hack! ?Thanks a lot! How do you find it?
Mostly by logic and luck
Once I figured out that this combo runs into some unexpected behavior I tested it thoroughly.
_card() and select list is also funny because it hyperlinks Unicode characters but I would not recommend it (although I use it for prototyping
Hi @Stefan_Stoyanov! Could you please write an explanation of your hack? The recording is sadly not available anymore
Please explain, I don’t understand that either, the link to the screen recording is dead and the GIF shows a table view, not a card view.
Hello @Nika_Vodvud and @Michael_Singer,
The sample doc page along with the video demo are available in my original post.
Thank you very much! Now I understand what you mean. Great tip!
What a life saver. Thank you for finding it and sharing it!
Wish it was a native functionality
