My final goal is to design a button that allows me to select the table inside my document as a first attempt, that way I can choose one of several tables inside the document.
Next I would like to know if it is possible to read the table, I have seen that with the coda api you have to translate the information and search fields by fields, and that is counterproductive, my idea is to be able to read the whole table. table and send it, I have not seen any information to integrate the looker studio api with coda.
I will tell you my ideal workflow:
I select table >> Albaram(for example) >> button to read and send to looker studio >> In looker studio I have that table to be able to work with that data.
Any information is important, any information you can give me would be of great help, thanks in advance.
