Hello guys.
Have any of you ever connected Coda with Looker Studio? I’m looking on how to do it, but i can’t find if there’s any way Looker allows this.
I have. But not directly.
The easiest way to do it is to set up an automatic export from Looker > Google Sheets
Then, either using a script or a pack Sync the google sheet to a Coda doc.
Let me know if you have any other questions!
@Scott_Collier-Weir
I’m trying to make a community conector so we can connect Coda to Looker, but i’m looking to make it the other way around. Send information from Coda to Looker
Yes! A community connector for Coda would be awesome. You can use the Coda API to build one. Let me know if any issues arise along the way.
Hi Eric. I think if the coda team would take a look and refine this integration Coda | Airbyte Documentation it would enable a whole slew of integrations including Looker.
