Is there a way for me to take something like this (I tried copy paste into here but it formats it nicely lol):
and format it nicely with images and links in a canvas column?
Coda indeed supports markdown, and you can create very fun stuff, here are what tools you have (like mardown)
You also have can divid space using /colums, also have visual line break using ***
You should investigate a little bit in all option available when typing the magic key “/” ![]()
Please let me know if you need additionnal informations
Cheers
Quentin
Thanks for the reply. I guess I wasn’t clear.
I have what is in my screenshot being pulled in via automation/Make.com.
I don’t know how to convert it via formula into something better to look at, with the links and images rendered.
I struggle with this too. After some searching I discovered that markdown isn’t generated automatically when using Make (I use it too). Sadly, we have to do without for now.
