Hi,
I’m trying to create a questionnaire. I would like to share the link publicly and collect results from different people at the same time. How should I deal with the issue of matching responses for individual respondents? Maybe someone could help me with this? Please find attached what I have managed to do so far.
doc (ready to edit): https://coda.io/d/Copy-of-Questionnaire_ddFf96sakRE/_suwoo
This is going to depend on how you are going to distribute the form. Coda has many strengths, however as a form I tend to use an outside service like CognitoForm and then connect it into Coda using Zapier.com.
If you’re going to have everyone log into Coda and answer the form, when the button creates a new entry you can have a column in the answer table called [User] and then use the User() function to have Coda automatically add the user into the form.
