Measure What Matters OKR Starter Kit Launched on Product Hunt
Hi everyone, if you would like to get started with OKRs (Objectives and Key Results), we launched a template today called the Measure What Matters OKR Starter Kit. We worked with John Doerr’s team (author of Measure What Matters) to create this template that gives you step-by-step instructions on how to create OKRs.
We would appreciate your upvote on our Product Hunt launch here!
Hi,
I am very curious to test your solution.
Since we are based in EU, I wanted to check your compliance with GDPR first.
I have found these…
https://coda.io/trust/tos
https://coda.io/trust/dpa
…but I did not find your company name listed here:
https://www.privacyshield.gov/list
Any plans on listing?
Being a consultancy in finance sector we have to take GDPR seriously.
Any other advice or hints regarding this issue?
Kind regards
Björn
Hi Bjorn,
Coda is GDPR compliant, but we have not yet gone through the self-certification process on PrivacyShield.gov.
We are looking into this process and will likely move forward with it, but don’t have a timeline yet. It should be pretty straightforward, but like anything involving lawyers might take longer than we’d like :slight_smile:
Cheers,
Chris
