I found a problem.
If I type directly to Slack chat this message:
[Go to Coda](URL then it works. It will be like this: Go to Coda
But when I send Slack message from Coda like this:
Format("[Go to Coda]({1})",Objectlink([Table]))
It does send the message but will not trigger and transform it to a url with the DisplayText. It only stays like this: [Go to Coda](URL
I tried both with the Slack options: “Format messages with markup” ticked and unticked. It is the same result.
Any hint how to send a message to Slack with URL + DisplayText triggered properly?
