Hi Guys,
i don’t know if this is known or even wanted but i recognized it is not possible to move or custom order the hidden columns in the layout view…
Would really appreciate if that would get fixed asap.
Thanks to the coda team.
Sincerely
Jannis
Hi Guys,
Sincerely
Jannis
They are usually hidden for a good reason. Having them in Alphabetical order in de hidden section makes them easy to find. If you find you are using some hidden fields frequently, I suggest you make an extra layout, attach it to a (hidden) view of your table and open the specific row with a button and call that layout (view):
Okay, thanks for that explanation @joost_mineur.
So there is currently no other solution to use a custom order than using a button and select a different layout?
Sincerely
Jannis
No, for the hidden fields there isn’t - as far as I know.
Okay, thanks @joost_mineur.
Sincerely
Jannis
