It is extremely helpful to be able to arbitrarily type @Text anywhere on the canvas and instantly get a list of all rows which contain that Text, then choose one and get a nicely formatted hyperlink to the row.
Is there any way to simultaneously select all rows meeting the search criteria?
What I would want is just the URLs, with the text matched to the name of the link (i.e. just as it is in the URL column).
I know I can get the list I want if I do a table lookup from the canvas. But that just gives me an unformatted list with commas between each URL. I am looking instead for a list with 1 line per hyperlink; can that be done?
And to clarify… right now I can individually choose each line - Breaking new, CNN, Fox News and the hyperlink linke I want will be created. That works well. But sometimes I might want to do this on a much longer list where it is not realistic to manually select each item individually. Is the same function available on a more automated fashion?
The end result would like like this - for any desired number of rows - and each of these an active hyperlink:
@Richard_Kaplan you can also use the .bulletedlist() formula on a Table filter in the canvas to display a bulleted list of results vs. a comma-delimited array! Would also use the Find() formula here to search the URL for a specific term (=lookup() is going to function more like a vlookup in excel, matching on the reference to a row or a column value vs. a search term.) Here’s what it might look like: =[Misc Resources].filter(Find("News", [URL])>0).bulletedlist()
